Ooops!!! spun car!!!
spun car other weeK and smashed rear wheel against a curb, the wheel is bent inwards about an inch, i can see the wishbone is bent, what else is liKely to be damaged.
managed to drive it home at 10mph car feels liKe its driving sideways.
and when it comes to zeds suspension especialy with the rear wheel steering, will any decent garage be able to fix it.
any advice apreciated
cheers
paul
Any reputable garage should be able to fix that. ;)
what else other than the wishbone do you recon will be damaged, considering the wheel is offset at least an inch?
have a chat with mike(mgh297) he did the same thing ..... ;)
If you have a TT then the hicas unit could well be buggered which would explain the feeling of going sideways
HELLO Zed's go sideways all the time ........ :rofl: ;) ..but yeah turboz could be right ... ;)
:slap: :rofl: :rofl:
Would be worth getting the whole rear suspension\diff subframe out and seeing what is bent.
I did the same thing in the summer
Bottom wishbone, subframe, shock absorber, wheel brg, and wheel
I had the whole lot out and changed all the bushes and hicas joints.
I would check the track arm, the driveshaft and top wishbone too.
I hate to scare you but i did all the work myself and it cost me nearly £700 and if you put the labour of a garage on top god knows how much it will cost.
manta!! thought you were off to spain!!
anyone else any horror stories liKe scrawni?
anyone any nursery rhymes to mame feel better?
ta
paul
I have the complete rear suspension and subframe from a 93TT in case you need anything.
Sev
07958535438
When I spun mine like that I organised for a specialist zed mechanic to sort mine out. I paid less than £700 and didn't need to worry about it.
Drop me a PM if you like and I'll give you the name and number of the mechanic...
  • 1 month later...
£270 for bottom corner, fluid cheKs and topup and putting stroseK front bumper bacK on!!
jobs a good un, thanKs mate.
wrong user login soz si, thanKs jamie.
paul
