heater
hi zmates
is there a way to bleed the heater matrix i had a heater pipe, between bulkhead and engine let go, i replaced it but since the the heater blows luke warm, or maybe its the valve not opening fully?
any ideas guys
regards big mo (man in black)
They don't normally give trouble bleeding but a couple of tips. Make sure the vehicle is positioned with the radiator higher than the matrix. There is a bleed point/plug fitted on the left hand side of the radiator, ensure it is removed. Let engine run until hot (don't rev) and the air should get forced up to the highest point which is the radiator. You should see it bubbling as it rises to the top. try squeezing some of the hoses as well but mind that cooling fan.
