- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
As many of you know i've been having continuous overheating problems with my Z, thought this was cured the other day as the main leak (behind the back of the engine) Has been blocked up.. it was a metal heater pipe.. what we did was cut off the pipe and made a gasket to cover the hole and use some metal sealant to cure it, car did not have any leaks from underneath, however it has been leaking coolant again overnight... I've done a plenum bypass on the car.. and it still seems to leak.. was driving home from work today and the temperature gauge shot up and then it went back down again and stayed at normal.. I've noticed puddles of water under the car when going out to it the next day... any ideas?
What i was thinking was taking it to a specialist and having the engine out and all the hoses completely replaced.. (will need new heater pipes too), how much can i expect to pay roughly if i wish to do this.. As I am bloody skint at the moment.. a quote on this would be great..
Any other suggestions to what it might be?
