How do I remove the sodding Gear knob!
Just got a new shiny knob to enhance the bling inside but can't get the knackered old one off. Is it just a case of screwing it off using brute force?
Any tips?
its a screw thread get a rag and a pair of mole grips wrap the rag around the knob and then carefully use the mole grips to undo. or use a tourniquet with the rag and an extension bar from a socket set (use the bar for leverage)
keep tugging the knob and it comes off............sorry :x:
regards,
alex
I think you have to remove the targa tops. Then you can get your back into it. :x: :rofl:
Any tips?
PM fiairladyzedgirll, she'll come round and pull on any knob apparently.
If budget is an issue, you could always try Hunnipie or Letsdrift.
Best of Luck.
Andy.
Peace and good will to all!!
Best of Luck.
Andy.
:x: :x: :x:
I still can't get the thing off. Have done the mole grips trick but it still wont budge. Managed to get a quarter turn and thats it. All I seem to be doing is twisting the gaitor round with the knob and am worried I will rip it.
Is my knob stuck like flies to shit or am I still doing something wrong?
push the gaiter down so it isnt being twisted by the knob. its has a ring that pushes onto the base of the knob. iirc the knob is bonded aswell as threaded so a qwick twist is required to break the seal. then it will undo. !its deffo an original knob isnt it. otherwise it may have grub screws holding it on.
The stock gearknob is screwed on damn hard and also has thread lock compound on (loctite). I all but destroyed mine when I removed it. Clamp the mole grips real hard and unscrew.
On mine I had to cut the leather off with a stanley knife to reveal the matal underneath and put my molegrips on that. Give that a go. PITA.
