9V regulated power supply
Hi,
Does anyone know the easiest way of getting a 9v 200ma regulated power supply from a 12v source in a car?
Vijay
We use a 9v power supply for PS2`s in cars, hard wires to 12v, i`ll check the amps for you.
Bob
Cheers Apache , yes something like that but think the amps would be too high on that one:(
Cheers Bob :)
Vijay
Cheers Bob :)
Vijay
Amps can be higher, it won't do any harm.
If lower however it will either blow or the volts will drop too low to be useable ;)
so if I used 1 1or 2 amp supply it wouldn't cause a problem????
Not a problem at all
If you need 200mA and have a supply of 200mA then the power supply will get very hot as your using it to it's maximum capacity. 1 or 2 A supply will do the job and also run cool.
