November 13, 200619 yr As title :cry: Arr well, it only failed on two rear tyres (I was expecting it anyway) and the near side headlamp aim out (also not able to adjust) So the headlamp will be removed tomorrow for investigation and I've just orded two new Toyo tyres for £152 delivered :D Retest is a week on Friday (MOT expiry a week on Saturday!!) Oh yeah, and a couple of advisories.... Both the rear steering arms with slight play!! Gona have to get it in for further examination.
November 13, 200619 yr oh dear, failing mots are a bummer arent they. Make sure they don't charge you for the re-rest!
November 13, 200619 yr headlight adjuster is an easy one mate, has a plastic cog on the inside that usually cracks and can be replaced by some model car cogs made of metal which will last better or take the high beam adjuster and swap it to the duff main beam adjuster.
November 13, 200619 yr Author oh dear, failing mots are a bummer arent they. Make sure they don't charge you for the re-rest! :rofl: :rofl: :rofl: :rofl: :rofl: You are joking, arn't you? VOSA regulation states that a re-test takes one hour, so the MOT stations can not book anymore MOT's in in that hour (depending on how many they have the ability for) so as the garage's now loose money, then most of them will charge (if not ALL) That's if they are on the new computerised system, if not then you could be lucky ;) As far as I'm aware they can't dodge the system, as to get a valid MOT cert, then it HAS to be on the computer, if it's on the computer, then it takes one hour = £50!!!
November 13, 200619 yr Author headlight adjuster is an easy one mate, has a plastic cog on the inside that usually cracks and can be replaced by some model car cogs made of metal which will last better or take the high beam adjuster and swap it to the duff main beam adjuster. I had all of them replaced earlier this year!!!! So I can't understand it :(
November 13, 200619 yr oh dear, failing mots are a bummer arent they. Make sure they don't charge you for the re-rest! mot prices have just gone up to £50 :xxx: if you go back within 10 days then you only have to pay half fee of £20
November 13, 200619 yr its cause they are plastic if u used nissan adjusters mate and break very easy. Take a look here for the parts required (50602) each pack has 2 large gears which you use ( 1 pack for each adjuster) http://www.goldstarstockists.com/tamiyaparts/tpx/tamiya-parts-50000-pictured-601-800.htm?PHPSESSID=ffd38524f522b15a5f519702e06617b6
As title :cry:
