I am haveing some solid hicas ball joints made for me so when I eliminate the hicas then the hub will have no movement at all, what I need to know is, if I lock the hub end of the hicas arm completely it will effect the up and donw movement of the arm wont it, this means it won't work properly will it?
I need some ideas as to how to do it all, please help.
Scrawn.
Not sure exactly how it works but I suspect if it was possible someone would have made them before as part of the elimination kit ...
Yeah I guess your right and the N/A toe arm is mounted lower and has bushes both ends to allow for movement.
you could always convert the hub to take a rose joint.
I was thinking about not having a taper onb the new joint but a paralel so I could fit a rose joint, but I havn't a clue where to get a joint from.
That would be a better option but like I said its getting the bits together.
