Media player codecs
im running media player 10 with the latest divx codec installed on 2 laptops and yet one mp4 (im pretty sure thats what it is) wont play on one of the laptops. Problem is this 2nd laptop doesnt have net access so i cant just connect and get the codec it thinks it needs.
I have searched around the net, but havent been able to find a codec pack for media player 10 (only 9 and this is already in mp10). Both machines running xphome and pretty much got all updates on.
Any way i can find out exactly what encoding has been used to make this movie, and then which codec i might need?
Thanks all
go into windows media player > Tools > Options > File Types > Select All > Apply
and job done
Vlc is a great program expically if you download large video files as you can view what has downloaded while the file is in use http://videolan.org
hth
Leight
Im actually trying to get codecs for my in car pc frontend, and it only uses media player so im stuck with that im afriad. thanks though guys
if you read the options carefully, then you cant tell it not to install media player classic, so you will have all the codecs and it will run through media player. or if you look on your pc where you installed the codec pack,
in the start menu > k lite codec pack > tools > gspot
that will tell you what codecs the file is using, then you can download just the codec and install it on the karputer
