is this normal?
for aslong as iv owned my car thair has been a thump noise that comes frome the back of the car evory time i put the car in gear and relece the clutch i was wondering if this is normal if its not whats wrong?
Sounds to me like your gearbox mount is had it, im usually wrong thou :)
i was thinking about the gear box mounts but they dont look bad but i dont know witch one would cause this
could be but it only dose it in 1st-3rd it something ill check in to when I do my clutch I feel that's on the way out I hear the throw out bearing and the clutch petal seems shallow
Prop support bearing, sounds like the rubber support section may of broken up completely and if so there will be loads of play, when you take the drive up it bangs upwards on the support ring, tends to sound quite far back for some reason.
Need to get the car up and take a look at how much the prop moves up and down in the middle.
Daveman
I just checked and the prop doesn't move wile I had it up i rolled the tier i had of the ground back and forth and it made the noise you guys don't think i damaged my drive axle by towing it do you ?
