Back brakes
How do you change the back brakes?
Is it as easy as taking the old ones off and putting the new ones on? a detailed description would be great thanx.
Detailed description LOL! Well your post wasn't very detail! What are you changing, rotor, pads? Either way, it's very easy. The Zed has floating rotors, so all you need to do is remove the to caliper bolts, slide the caliper out of the way... then the rotor can be taken off. It may need a tape with a mullet to loosen it up. Let me know if that's not detailed enough.
Good luck (Note: when changing rotors, it is always important to change pads also).
I can see it now
:rofl: :rofl: :rofl: :rofl: :rofl: :tongue:
LOL Pick on the dyslexic guy!!! Take two... it may need a tap with a mallet. That's it, I'm going home now :(
sorry forgot to say, im changing the pads. thanx for the detailed description tho
Someone ring the RSPCA :shock:
