cutting out?
ive noticed when i slow down for a set of lights for example and i dip the clutch the car almost cuts out and i have to rev the car a tad to stop it
any ideas?
any ideas?
Idle solenoid! either a bad connection or soleniod/unit needs a clean
Back of the Plenum near the battery! two connectors one yellow for the A/c increase and one grey connector this is the one you want to check
nice1 :D:D
what u do just take them off and clean them out?
clean the connectors?
nice1 :D:D
Yes Mate! Start with removing the connectors and cleaning the pins on the male and female connectors! Just be carefull not to bend or damage the male connector pins . They will probably be slightly corroded;)
also have you recently fitted BOV's?? sometimes you need to adjust them to stop it
Mike
its had BOV's for ages m8, never had a prob till now
how would u adjust them anyway?
most bovs have an adjustor screw on them :)
Idle valve is the yellow connector, the grey one is the fast idle ;)
