  1. Tap the 3-dot menu (ā‹®) in the top-right corner of the browser.
Americans call it bondo..
but what would it be called in the uk? Im looking for what they call fine bondo and fiberglass re-inforced bondo? Confused!
Isopon P45? Body filler.....
AFAIK its just body filler, plastic padding do different types from standard filler to superfine and glass fibre.
PLastic padding? Whats that as it sounds like the stuff im after... planning on using it for some custom interior work as it sounds easier to work with than pure fiberglass..
Glass fibre reinforced Bondo over here is P38?? I think.
Known generally in the bodywork game as "fillagap" or "liquid chassis"(illegal use).
Basically is flexible resin with fibreglass strands mixed in.
Chopped strand mat is notoriously difficult to work with. Easier to use woven material and just add more layers.
If you're going to be doing any kind of bodywork, custom or otherwise, I strongly suggest you go here: http://www.cfsnet.co.uk/
I order from them regularly and TBH I wouldn't use anyone else.
Ā
Ā
Leigh
If your after an ultra smooth body filler try UPOL DOLPHIN GLAZE its not far off a liquid but fantastic for the final skim as you never get pinholes in it .
:dance: :dance: :dance:
Thanks guys, im trying to get a good finish to an intergrated touchscreen in my zed. I will let you know how i get on! (as im usually sh1t at stuff like this! thankfully ive got a spare center section to practise on first!)
