washer fluid
i confused, i ahve a 90 tt manual, where do i put washer fluid? is it near the trunk area above the left tail light?, how much should i put cuz i put about 3-4 cup fulls and it doesnt even say 1/2, also when i lifted the mat, on the left side where the fluid goes, im not sure if it was the fluid or water but there was some wet stuff, maybe its leaking? also how do i spray the washer fluid onto my windows? do i have to push in the little thing that you twist for the wipers? if i push in the twist thing i hear like a humming sound as if it was trying to spray the washer fluid but nothing comes out, whats the deal? thanks help greatlyu appreciated
if you press the button that is the front screen which you fill up on the o/s/f just behind the headlamp. if you push the little rear wiper switch right up it will wash threar.
unless you have a swb and its at the left rear above the rear light.
yes mine is on the rear right , sorry im in USA i have the american veriosn with the steering wheel on the rleft side insteado fo the right so a few things may be changed around but its still the same car
