Help with four wires (clock)
The clock has four wires coming out the back and into a plastic plug.
Can anyone please tell me what colour wire goes to where?
Blue
Black
Green
White
I would think you would have a + feed , + Ignition feed, -, and light feed to dim it, I'm sure Andy should know
Ian - I'll be back in a few moments with a picture and where the wires go ................................
Right then
Clock------------> Car
White ------------> Blue/White
Black ------------> Black
Blue/White -------> Yellow
Green/White -----> Green/Red
Yellow = perm +12v
Green/Red = Lighting dip
Black = Earth
Blue/White = 12 volt switched
Hope that helps :)
Right then
Yellow = perm +12v
Black = Earth
Hope that helps :)
Thank you very much Phil :bow: :bow: :bow:
i see someone has time on there hands !
My car interior is in bits as it's about to have a re-trim, and anyway I'm on late shifts this week :tongue: :rofl:
sorry to hi jack the thread Mac ..but the yellow 12volt permanent feed to the clock etc ...do you know which fuse its fed from ??? ive lost the 12volt feed on that same cable
thanks
Steve
thanks
Steve
Not yet Steve all I know at this stage is my clock does not work and it is not the clock. I now need to test each wire to see if they all have a connection at the other end.
  • 1 year later...
thanks
Steve
Did you find this out as mine has lost feed to ??
Can you not highjack the perm + feed from the stereo or ciggy lighter?
Does the interior light work? They're both fed from the same fuse
