can any one help. i had to call out a plumber about 6 weeks ago to myhouse in bradford as there was a leak some where. turned out to be the seal around the ball cock and cistern just had the bill and it's £169 :rant: :rant:
his got to be taking the p155 anit he 3hours labour :eek:
i remember do the same thing for my mum and dad about 6 years ago and i no it dint take me that long, and dint have a clue what i was doing
any advise before i ring him about this
thanks graeme :bow:
if it was an after hours callout then that price is about right, but if the seal between the ballvavle and cistern was leaking it means that it was over flowing (due to worn washer in the valve) and he may have put a new valve in (about £6 from B&Q) then it should have only took about an hour so you should really be looking at around £60
yeah the parts were £6 so that sounds like the bit, and no not after hours so i'll be on to him tomorrow, thanks lads
yes mate - i'm a plumber and he's taking the piss.
is it the float valve in the cold water cistern in the loft or a WC cistern - either way 1 hrs work at £60 plus parts max £10
unless he has had problems shutting off the water for any reason.
Pm me if you want mate
Regards,
alex
thanks graeme :bow:
Give me a call. Not Now but AM please (not at work at the mo) 07775633561
It does seem a bit steep. I did the same job yesterday for £48.00 plus vat.
I need more info to comment. Regards Neil.
bobby ball is a thick plumber
LOL you coont. I hate blue Zeds.
