Tip for people with Z1/SPL rear camber arms
If you've got them you'll know that you cannot get hold of a grease gun adapter to fit the nipples.
Paul C told me how he did his, but I couldn't get the thing to work. The only thing I greased was me. When I suddenly thought. I knew i had a couple of vacuum house push fit connectors and thought they resembled the shape of a grease nipple. My Idea was to put it into the hose and then into the gun.
Then I realised that the internal diameter of the 3mm connector was about the same size as the grease nipple and hey presto.
So if you have these and they are creeking just get a 3mm straight Nylon vacuum hose connector stick one end into the grease gun like you would a grease nipple and the other end over the small nipple and hey presto.
No posts to show
