Decat pipes-?difference between series 1&2
Hello guys,
Need to get decat pipes as my right side cat pipe is leaking. I have a 94 TT, series 2 and heard before that the decat pipes for series 1 and 2 are slightly different. Does anyone know if this is correct before I get a set.
thanks in advance
ronnie
The series 2 has a pre-cat on the passenger side and so the cat pipe is shorter on that side.
On the series 1 they are equal legnths.
Baz
Baz
thanks baz, noticed that you have a series 2. where did you get your decats from?
cheers
Hi Mate,
I got my megan decat's and downpipes from chris@getgreddy, if you go for downpipes too they are considerably more awkward to fit, i fitted mine while i had the gearbox out which made it much easier.
Baz
