help needed
Drilled a hole throw the fire wall to put boost controler cables threw near the throttle cable and smashed the lid off a little black box on the inner wing with the drill it has a plug on the bottom and a small vacum pipe connected .It runs but misfires badly does anyone know what it is and how much are they thanks taff.
All that bloody space and you had to hit something. PMSL. dont that always happen? I hope its not too expensive Taff. Not a clue what it is tho.
Hi vinney dont surpose you have any whats what under bonnet links for the tt do you mate ive done a search and cant find anything cheers taff.
Sounds like the boost sensor for the gauge.
Baz
Thanks mate will it disconnected cause it to misfire thanks.
I've just been out and disconnected mine to be 100% and it made no difference at all.
Baz
thanks mate i dont know what ive done mine missfires unpluged or pluged in anybody got any ideas thanks taff.
av you checked that all your coil pack connectors are pushed on. or have you looked for anyother pipes that might of bein knocked off while having a route in that massive space in that area of the engine
Thanks mate sorted now it was a dodgey coil pack connector plug .I dont know why because i never touched it .thanks guys .
