Hi well I finally got hold of a working used Tps this week coz mine was cracked, i got chance to have a go at fitting it tonight all went great, mounted it pluged it in, connected datascan, ignition on and set the tps at 0.44v only to find that the tps was open at 0.44v, and the Egr sol was off. So what i did then was adjust the Tps until it was closed, when i reached this point the Tps was reading 0.30v-0.32v and the Egr sol was on, so i started her up to see what happend and it idled fine with the Tps set at 0.32v + Egr sol on and the AAC was 24 then changed to 12 after i went for a spin round the block, the only differnce i noticed that wasn't there before is that when id come to a junction and put my foot on the clutch to cruise the revs would drop to 300rpm - 500 rpm then jump back up to 900rpm or so then settled at around 750rpm, same would happen if i high revved n let off the throttle.
The problem is i know the Tps should be at around 0.44v, Will my Tps being set at 0.32 cause any problems or damage to my Zed.
Cheers Guys wicked site, I couldn't live without it now.
Oh and does anyone know how i can get hold of RiceRocketUK I need to buy new brakes, Ive been emailing him on ebay for days now but getting no reply.
