Power Steering Question
guys, my new power steering hose is due to arrive on friday, so the car will be back on the road. hurrah!!
what fluid should i be using in the power steering system, just your average-joe ATF? or do nissan have some wonder fluid i should be using?
It's Dexron Type I or II ATF you can get from most garages etc.
yeah, so it is just atf then? :) average-joe atf will do the job?
Didn't you read it? LOL
There's a few types of ATF and the recommended type is Dexron LOL
Using any other could cause the seals/pipes to go I suspect.
it has been a long hard day, so any preferance over I or II - also, how much of it will i need?
I'm sure it's meant to be Dexron 1 but I can only ever find Dexron 2 in the shops.
I think the type 2 is an updated replacement with the same properties.
A small 1/2L to 1L size bottle will be plenty, usually costs about £6 or something.
i can now see that Castrol are making an ATF Dexron III - is this different and not advised in the steering, or just the new alternative to 1 and 2. sorry for all the questions, but i dont want to kill my steering, asi hear the 300 can be a bit picky on this front :)
Yeah I might be wrong actually and it's 2 or 3 that's in the shops! :rofl:
I'm sure Dexron III is fine :)
