compression test results
Went out for a drive and no.1 cylinder burnt off all the oil and was dry.
Did a dry compression test on the front 4 cylinders, couldnt be arsed to do that back ones.
Not sure if I managed to get the tester tight enough as the metal shaft wasnt long enough, so had to do it up by twisting the rubber hose.
Anyway, all the front 4 showed 135psi, which is a bit low isnt it?
But atleast they are all consistant so maybe the rings are ok.
Didnt do it wet, guess you need some thick oil?
BTW, didnt have throttle opened when doing it??!?!?!
Doh, will it effect the results??
If anything it would make then a little higher which is better?
Thinking its the turbo now......
How do you make that out?-should have all plugs out,throttle wide open and crank engine till guage tops out, try that and see the difference! :)
