Charging Stabilizer
Are these worth getting as my na is not very responsive pulling off
Ebay item
I find it difficult to believe that this would make a noticable difference, cars already have a voltage regulator/stabiliser circuit.
Oh thanks mate, hopefully the DTA chip with sort out the pulling off problem
If you have a problem with a standard setup and standard chip then it's unlikley that a modified chip will fix it. I'd recommend identifying the root cause of the problem before making changes.
Hmm maybe its the fact I cant drive a manual Z, I just not great at pulling off at low revs, hmm I do some checking of cables
Burf .. try a grounding kit .. its an old car with crimped terminals on the cables .. oxidisation will give you a small resistance when starting etc .. the voltage stabiliser is useless IMO , your ECU and delicate electronics should already some form of supresion built in to compensate for the "Dirty DC" an alternator produces
John
I think there is one on ebay for £30, is this cheap, any advice where to buy one
how easy is it to fit a grounding kit?
Pm the guy and asked how easy they are!
if you look on the review section i did a review of Shrimpy's grounding kit
Overall GOOD buy!
