Power lead through Bulkhead
Fitting my amps tomorrow :hyper:
Can anyone advise on the where and how to pass the live from the battery through the bulkhead? :confused:
I've run mine through the grommet where the bonnet release cable goes thru - used an old coat hanger going from the inside and then secured the power cable to it and pulled it through. You will need to remove the drivers footwell trim.
If you can't find a spare hole, it can be easily cut with a hole saw. Always cut a bigger hole than you need now, as you're bound to add more cables in the future for other stuff.
i found that the best place was the passenger side where the main harness comes through to the ecu.just need to remove splash guard in the wheel arch and feed the cable through the hole next to the battery.
Thanks for that guys most helpful as ever :bow: :bow: :bow: :bow: (One for each of ya!)
On a mission tomorrow then :dance:
