sicky seatbelt
Passenger side seatbelt is getting more+more reluctant to rewind itself, is this just a case of removing the door panel and squirting some oil in ? Any tips for removing the door panel i.e. are there any of those poxy plastic clips that always break ???
I had the same problem, I removed the belt and took of the little white cover on the side of the reel. A few broken bits of plastic fell out. It works fine now ??
It locks and retracts.
On the other side of the belt there is another small plastic white cover, in there is a small plastic cup and spring with a small ball bearing in it, this also came adrift on mine but is easy to put back.
Hope this helps ;)
