[B]fuse for the alternator??[/B]
The battery dashlight is alway on.. Then the the hicas, abs the the mission oil, diff oil light. doesn't seem to charge.. But heard that some jap cars has a fuse between the battery and alternator.. Is this the case for the 300. If so, where is it located??
Check the black fuse and relay box under the bonnet (Inner wing ), check the fuse marked up "Engine Cont" should be a red 10 amp, when these fail you have the symptoms you have described.
Daveman
yeah, my battery light is always on but was told it's to do with the charging circuit being faulty or something!
