rear hub bushes
Has anybody changed the 2 bushes in the rear hubs the one the rear upper arms connects too and the one the small link[traction ] arm connects two .Ive changed all 3 hub bushes on a s13 200sx before 3 because no hicas not too bad to change hole cutter to take centre out then hacksaw to remove the outer steel bush shell then chisel the shell out.But the 200 sx has cast iron hub not alloy like the zed .Ive changed the small link arm bushes sub frame end with powerflex bushes and fitted cusco rear upper arms .thanks taff.
No posts to show
