Auto holding in 1st?
Hi guys, I have a JDM Fairlady TT and for its latest trick :smash: it has decided to start holding in first (while in drive) until you take your foot right off the pedal, then it will drop down. I have cleaned the plug from the TPS as it was green and corroded, this made some but very little difference. The chappy at Z world said something about 0.4V at the wires or something?????? PLEASE ADVISE. :(
JASE
If you have a multimeter put it resistance and put it on the two terminals of the tps. Make sure its base voltage is 0.4 ohms resistance when the throttle pedal is not pressed. If not adjust it by slackening off the two bolts, screws and turn slowly until its 0.4
Cheers bro, but theres 3 pins on mine? :cry: PLEASE HELP!
Jase
from memory i think its the middle and top pin ?
Have you checked the oil level, its very important ? and dont for get to chec it when thecar is nice and warm and you have been through the gears and check with the engine running.
resistance? err you want voltage to be 0.44, dont know what resistance has to do with anything.
Many thanks for all your all your help guys, im just praying its not the box it seems to work sometimes now and not others. B~ST~RD of a thing!
Cheers Jase
Mine used to change really late in 1st-adjusted TPS and it worked!
Love the RS2000-by the way!
