Another tyre question.....
I had to take my zed out this morning, the first time in the wet for quite a while. I normally take my other car out when its pissing down but anyway, (get on with it!), I just noticed that on almost every pull-away the arse end was-a-wrigglin' and on most corners the beast kept 'drifting' to the other side of the road. A bit scarry at times!.
I am running Pirelli P6000's at the 'mo, and have come to the conclusion that they are shit when driving in the rain (still have about 3-4mm depth) There not that 'grippy' even on dry roads. A friend of mine has a TVR Grithith or whatever its called and he recommended Bridgestones?.
Question really is - does anyone else on here use P6000's (or have used them), and does anyone also have experience with Bridgstones??.
Tony.
Pass on both of them,But what I can tell you try BF Goodrich Profiler,and tell me if you can slide it in the wet wink.gifI would not try anything else.
cheers for that, 'spose you wouldn't know a good place to get them from down here in the south?.
Tony
Rock_Star,Dont know but I pay £330 all in for 265/35/18 for a pair of rears,and like I said wont slide in the wet wink.gif.
do you not maby have a rear shock or hicas link problem?
If its as bad as you say, cant be all tyres.
Bridgestone so3 are the tyres for me, ill never swap on to anything else.
I'm 300ZDING across the Universe, only going forward cause i cant find revearse :D
MichelDever on the web quoted me:
Size Bridgstone SO3 Toyo Proxes T1-S
225/40ZR18 £141.52 £135.65
235/40ZR18 £166.20 £153.27
265/35ZR18 £206.15 £173.83
285/30ZR18 £266.07 N/A
These are fitted prices, VAT, Valve and balance included, they will do mail order.
brian.kerswell@micheldever.co.uk www.micheldever.co.uk
