May 25, 200620 yr Hi tried loading some piccys onto forum but every time i try it says ?????to big max allowed 500 my piccys are 641 mark
May 25, 200620 yr well that was a fantastic help you dont bloody need any help, you just said yourself why they wont load it says max size 500 and your trying to load a pic over 600... what bit dont you understand and need help with fella? :headvswal
May 25, 200620 yr Author only just got camera ive loaded piccys onto many other sites i dont even know what 500/600 means how do i alter it
May 25, 200620 yr only just got camera ive loaded piccys onto many other sites i dont even know what 500/600 means how do i alter it when you view the picture on your pc, if you right click and edit, it will open in paint, you can then adjust the size there or if your hosting the pictures on photobucket, click edit on the pic in your p/b file, and resize it.. 500 is the size limit, any bigger, and it can take a while for pages to load, especially if there are a few pics in each post, so its there to make viewing easier, also if the pic is over 600, then it proberly means its larger than screen size too
May 25, 200620 yr just to add to what T-Pot has said, if you find that your picture is too big, use the Stretch function of MS Paint to reduce the size of the picture (change the 100,100 to 75,75 or something). it should be ok then.
May 25, 200620 yr Author Thanks will try that i am better with a spanner than these pc thanks again mark
mark
