How do you know if you have this, what are all of the symptoms?
How can you check if you have it? any tests you can do etc
Membership No 0780
INSURANCE GOOFA
Do a ecu check if you get code 34 = det sensor
Code34 will only show if det sensor or its harness has failed. It does not show if you had had Detonation.
Detting is audible, kind of like the sound of lots of metal screws being shaken in a tin can.
Thats a similar noise to what im getting, is there any way to check for definate?
Any other symptoms to look out for?
Membership No 0780
INSURANCE GOOFA
what petrol are you using bud, i only use super unleaded or optimax, but mine is uk and is desinged to run on normal unleaded
you would be better going to a rolling road and get them to check your afr and they will listen for det with an aftermarket det sensor
worth spending 40 odd quid to find out for definate
Mike
]Mines uk too mate,
I always use optimax bud
Membership No 0780
INSURANCE GOOFA
]Mines uk too mate,
your car maybe UK, but is the new engine?
thats what i was going to say next, the engine may be jap, therefore you should be running super
but then again, its still a uk ecu, so shouldnt really make a difference (should it)
either way i always use optimax anyway.
Always have while ive had the car.
Where is the rolling road places round here?
Membership No 0780
INSURANCE GOOFA
andy unwin, in newcastle
Ill give him a bell and see how much it is.
ill be back in 2 mins
Membership No 0780
INSURANCE GOOFA
really hope its not that m8
u really do have the WORSE possible luck :(
Well the engine is currently under warranty so if it is something like the engine is fooked it will go back.
Membership No 0780
INSURANCE GOOFA
Just been out with the datascan.
Results will be put up in a separate post.
It said - car started 29times with the error code 12 AFM
Apparently this could cause the rattling - someone said
Also still got the TPS even though ive taken off and cleaned slightly (not that much as dont have stuff here to clean it with
Membership No 0780
INSURANCE GOOFA
why would the engine make any difference, they are the same, differences are all in the ECU.
