- Replies 35
- Views 661
- Created
- Last Reply
EvoluZion3 8 posts
takemetothepub 2 posts
xav2075 2 posts
markGSI 1 post
one for the sparkies/I.T. guys on here.
* bought a new PC a few weeks ago. nae problems with it except graphics card is a major let down (ATI X550)
* bought a new graphics card (ATI X850) which requires extra power feed from power supply unit. fitted. nae problems. flying (except the occasional beep while playing graphics-intensive game, dont know whether its cos im holding a direction key down for a while or whether its from new card.) otherwise no problems
* try to run new pc from 4-way power point so its mated with new LCD monitor, printer etc. but that tripped the fuse box downstairs.
* run PC from its own power point and its fine. nae problems.
* our area had a power surge a few days ago (not my fault i was at work!)
* used PC. nae problems.
* couple of days ago the PC trips downstairs out again :confused: for no apparent reason.
* reset trip. happens again. :confused: take side of PC off, check all connections/cards etc. everything ok.
* the only thing i can remember installing is a USB cable with a green LED light! unplug that, and it works! plug it in while its running... and it still works...
* reset trip. plug my old PC back in (same socket, same lead). runs fine.
* plug new PC back in. trips out.
* unplug DVD drive and gfx card so ease load off PC PSU. switch on. works fine (except i cant see anything cos gfx card got no power!)
* put OLD graphics card in, plug DVD player back in (this works fine too). TRIPS OUT! :confused: so new gfx card not to blame!
* put NEW graphics card in, but leave couple of other things unplugged. works fine! :confused: :confused:
* swap trip plug downstairs with the one next to it (same rating :D ) to elimiate that (maybe local power surge weakened it or sommat)
* put old harddrive in, in place of DVD player (so i can copy some files across quickly). works fine, but then when i switch on again after a while (made no changes), trips out!
* but now while im typing this, i have new gfx card in, 3 hdd drives plugged in, and it works ok.
its so intermittent its bizarre! when its on, it STAYS on, but when it trips, it happens literally when I flick the switch to turn it on. its sure not the gfx card, nor anything else inside the pc (they all work individually). the PC's PSU is rated 350W, 220-240V. ive narrowed it down to the following:
* PC PSU is a little faulty and works intermittently (in which case, remove porn and take back to PC World)
* the PC, being quite powerful, is running close to its load limit so that sometimes it will cause a trip, sometimes it wont (upgrade trip to higher load :x: :x: or make do with no hard drive :( )
* the local surge has boogered something up (remember i did have a trip before the surge but that was when i ran it off a 4-way)
* the bloody thing's cursed (take to church and bless with holy water)
any ideas whats wrong cos its doin me bone in!
