Apexi AVCR
who the hell can set one of these up b4 i blow my engine, im a dick i know, b4 i went away i had a little play with it and well, its showing im running way over 2 bar so that needs to change QUICK!!!!!!!!!!!!!!! but it moves like shit, i take it coz there is no fuel there, can anyone help, im bac now for gud, so loads of dosh and plans for the motor maybe.
thx karl see you all at japfest or pauls bbq.
FFS Karl.....
knock it back bud :eek:
Mine runs just over 1bar (17psi) on the AVCR and the fuel injectors are at 92%.
If you really are running over 2bar then you will be running seriously low on fuel.
Not Good :nelson:
FFS Karl.....
Not Good :nelson:
do you know how to set them up mate, i dont have a fuking clue bud.
give us a ring mate 07867525420
Need to sort that ASAP mate, you'll be running very lean and could blow your engine. Def stay off boost! Killed my last Zed like that.
blackmagic sorted me out today thx guys, i was on the fone with him at about 0745 and it is now set safe, i may have another boost leak coz its set up to how his is and i can only go to 0.6-8, so i will need to get it into the garage to have a look.
karl
No probs bud :duffer:
At least your safe for now bud till you get it setup properly.
May not have a boost leak if what you said above was true coz to be able to reach that level it must be fairly well sealed.
However...every Zed is soooooooooo different its all down to the setup...
I hope you get it in soon and get the full potential of ya ride :nana2:
You can tell if you have a boost leak (well, vac leak) with the AVCR. At idle I think mine reads about 450-480 mm per something or other. I spent ages searching TT.net when I was setting mine up and I came to the conclusion every car is different.
Set the boost level you want, then set the duty at about 65%. Go for a run in your car and if it spikes reduce the duty a couple of %. If it doesn't reach your boost level quickly enough then increase the duty a couple of %. After a few full throttle runs it starts to self learn the duty anyway and changes it for different rev levels.
This is what I did, and mine works fine now. A little bit of boost spike but not much.
Hope this helps.
Rob B
Just another note. I was aiming for about 1.1 bar when I set the duty to 65% so if you don't want to run that much boost, start at about 60%
Rob B
  • 5 months later...
Im running 60% boost and 30% Duty and getting 16-17psi (1.1-1.2bar)
Fook its fast :hyper:
himate i have the avcr and have had basic mods like de cat dual induction kit jwt chip s-afc and avcr controller i want to up boost to 1 bar o 1.1 bar how do i set it on the avcr which screens am i going on and what do i set up any help would be appreciatd tnx
