Bird
you left oil all over me dads new drive from ya Z today :eek: :headvswal
he's doing his nut :rant:
just park on the street, till ya get ya engine sorted LOL
at least its under warranty :nelson:
he's banned all Zs from the drive now, unless you put a ground sheet down LOL
  • Replies 45
  • Views 1.5k
the only way to get money back would be to strip it for parts, but it's a hassle if you don't have the space.
I would say if your gut says stick with it then do so, oh and take a pic of the leaking part we might be able to tell you what it is.
this is the parts but the picture has turned out quite blured, this is the part taken from my old engine before chunk took it all, if chunk reads this he may be able to put a better picture of it up
Membership No 0780
INSURANCE GOOFA
yeah, ill probably have a pop down, you going to have a look at the car for me at yours are you?
It'll leak on your drive mind :x:
Membership No 0780
INSURANCE GOOFA
Strip your car and get a low milage zed imported from Japan with a 6 month warranty with the importer.
Hmm i wonder how much it would cost to replace every single part in a zed with new parts apart from the body - £15K?
well ive almost done it now, not with brand new parts though :headvswal
Membership No 0780
INSURANCE GOOFA
is that where you think your oil is leaking from?
I had exaclty same problem from that part, small crack in the housing and the pressure was blowing the oil through at a tremondous rate.
thing is, when you strip it to get at it (involves a head off :headvswal ) you cant easily see the crack/s
had 2 of them blighters split on me since Z ownship so must of been a bad casting batch at somepoint in time.
Yeah thats where its coming from, Is it worth fixing???
And do you know what the part is called so i can get it on the warranty
Membership No 0780
INSURANCE GOOFA
Once i had a Ford Orion that had a cracked sump after i tried to take it off roading in Wales! Regular silicon sealent from a DIY shop sorted the leak until the car went to the scrap yard a year later.
Sp cover the area in that for a while just to slow the process down :confused:
Membership No 0780
INSURANCE GOOFA
Have you looked in the workshop manual Bird? I recognise the part but can't remember. You should be able to find it easy enough as its quite obvious.
Do you have a link?
I looked in the online manual but couldn't find it on there
Membership No 0780
INSURANCE GOOFA
oil filter tree housing/oil filter bracket as said above
Can this be fixed with the engine in the car?
Membership No 0780
INSURANCE GOOFA
i think 2 of the bolts are near on impossible to get at,also the gearbox to engine bracket gets in the way slightly,im not sure but have a look at maybe dropping the crossmember,but i still think you will struggle,so engine out
Yep, that sounds like the thing
this is what it looks like only less blured
Membership No 0780
INSURANCE GOOFA
I thought it was the oil tree but i didnt like to call it that incase i just imagined that stupid name for it :rofl:
As for removing it in the car :headvswal would be the answer i think
This may sound stopid but swap the one in your hand with the cracked one on your car. :smw: :rofl:
well the engine is covered under warranty so i need the exact name of the part and if possible a part number, can anyone help with this?
Also i couldn't do that as i sold the old engine and although the old one was knackered i couldn't be dishonest about things and put another knackered part on that one, i know there is a few that might do that but not me,
Also as previously said we can not get the part out because the engine is still in the car
Membership No 0780
INSURANCE GOOFA
