Door open warning light.
Any idea how I can check to see why this light is not working?
Also what is the CAS overheat warning light for?
check the bulb,it has probably blown,remove instrment panel to fix
i think you may mean CAT overheat,id guess if an aftermaket exhaust was fitted,common problem is the 2sensors that screw in to the middle section seize in there,most just cut them,and if you have a straight-through exhaust there not needed,remove bulb,whilst your checking door light,or check sensors underneath
greg
I tried to run a diagnostic on my auto gearbox but could not get it to work. ANy help on this, Thanks
