power check
can anyone help please when i have the light switch off that turns lights on. doing a multi meter check the two top pink wire give me 12.3v should i get any of the bottom ones. the prob is the lights are out only main beam have checked all fuses and relays. only one not checked are ones behind fuse panel. also the circut breaker behind the fuse panel as it says breaker does it need resetting or anything is short in system anywhere. i have looked at the wire sheet and i think the one i get power from on the light switch is 5=6 thats all. cheers :confused:
change your bulb :x:
