Hmmmmm Bigger pipes
Well the work is never done!!!
Started installing my larger intake pipework today!!
Jesus the 50mm pipework was hard work but this new 76mm pipework is a knightmare but were making headway ;) main problem is as its cromed we cant mig weld the bits together so like last time were having to do the joins with silicon but with decent clips nice and tight it should be fine :)
Other problem is the hole below the lights is not quite big enough so gonna attack the car with the grinder in the morning :p
Just to show how big the pipework is going to be now, i have taken a pic of the previous compared to the new stuff :D
Mike
  • Replies 30
  • Views 825
well almost finished fitting the bigger pipework :)
not as bad as i thought but its a little closer to the manifold so we need to remove it all later this week and heat wrap it all to protect it.
Took a few pics on my phone to show the new filter positions
Left side
vbgarage.php?do=getimage&id=3700
vbgarage.php?do=getimage&id=3701
Right Side
vbgarage.php?do=getimage&id=3702
vbgarage.php?do=getimage&id=3703
Should get some nice cold air flow now :)
Mike
No MAFs I see, going back to the MAP setup?
i never went back to mafs so yes went from a HKS map sensor to a 3.5 bar AEM sensor :)
Mike
oh right my mistake, I thought you did.
i was going back to them but decided not to in the end :)
