My stock oil pressure gauge is totaly rubbish and doesnt work most the time. I have bought a set of guages one being an oil pressure gauge with its sender. I'm not bothered about the oem gauge so im just going to get rid of the old sender and fit my new one in its place (connected to new gauge).
I will probably experiment with connecting the oem gauge to the new sender as well as the aftermarket one as the voltage should remain the same so they should both work.
I was wondering though if the ecu monitors oil pressure like it monitors water temp etc, if so what effects could this have? Also is there anything else important connected to the stock oil pressure sender or can i just chuck it?
Next question is what size thread does the stock sender have? So i know if the new one will go straight in or not.
Hi all
Many thanks, Ed
