Urgent Help Needed
Hi guys,
Just picked up the new car and got home about 45 mins ago whilst it was just getting dark, turned on the lights and nothing is working! The exception to this is when you turn the lights knob to standard beam it reacts with Full Beam. Turning the knob to side lights does nothing, no front, no back lights. Pushing the indictator stick forward to turn on high beam does nothing.
All other electrics are working fine. I'm guessing when the mechanics were changing the odometer from km to miles they've put the high beam connector onto the regular beam or something.
Can anyone advise the location of the connectors so I can check?
Any help much appreciated.
Paul.
check the fuses in driver footwell first next accelerater
Hi, I've checked the fuse (3rd from the left on the top row) and it looks fine. However, just to rule it out I swapped it with one of the other 10A fuses and still no joy :(
Can anyone suggest another solution?
I've done a search for my problem and everyone seems to point to this fuse, 3rd from the left on the top row but as I said that doesn't seem to be resolving my problem :(
Any help is much appreciated.
Paul.
Check the dip beam fuses under the bonnet in the black box on the passenger side inner wing, they are marked up on the lid.
Daveman
Hi guys,
Paul.
Got a similar problem buddy
http://www.300zx.co.uk/forums/showthread.php?t=70863&highlight=lights
Daveman
Which one is the dip beam fuse?
cheers
