Speed Humps
Hi All
Noticed various comments over the years about these- even damage & grounding especially for Z'ds!
Came across 1999 Road Hump Regulations today- apparently max hieght permissable is only 100mm- trials of different humps only used 75mm!
Seen plently higher than this especially in London- if you run foul worth measuring, photographing & taking advice I reckon as they dont have a leg to stand on
- What do you all think?
Regards
Dave
The guys in Leicester should read this, thats speed hump city and they are a lot bigger than 100mm
Hi All
Regards
Dave
Excellent piece of research :bow: Armed with this info i'm off to measure the humps on my estate. Fed up of catching exhausts, and we're just about to have a body kit fitted.
They should be removed. They are bad for the environment, I have to take the long way everywhere in south London to avoid them, burning more fuel thus harming the environment un-neccessarily. Then again my car is slammed to the deck.
Just a bit more stirring!= even more interesting, D of Transport recommendations under 1996 regs!;
Table 1 - Appropriate Road Hump Heights for Approximate "Between Hump" Mean Speeds
Road Hump Type
Mean "Between Hump" Speed (approximately) 30mph
Mean "Between Hump" speed (approximately) 20mph
Suggested maximum on/off ramp gradient
Round Top
50mm - 75mm(1)
75mm(1)
N/A
Flat Top
50mm - 75mm(1)
75mm(1)
1:10
Raised Junction
50mm - 100mm
75mm - 100mm
1:10
Cushion
60mm - 75mm
Without other measures may not be appropriate
1:8
"Thump"
35 - 45mm. Up to 50mm heights have been used, but may cause unnecessary discomfort
Not really appropriate where low speeds are required.
N/A
Note:
(1) Heights above 75mm are not generally recommended
Regards
Dave
Thank you very much indeed! Much appreciated. There are a couple of humps round my way where the car grounds if I've got people in the back. Cambridge City Council.... your ass is mine!!!!!
