o2 readings
Checked my o2 sensor readings both sides on the Datascan. On idle they both sit just under 30, and at 2000rpm they both swing between 30 and 65. Is this a normal readout?
Thanks.
I presume you mean 0.3v and 0.65v ? If so then yes, that's about right, the actual voltage is unimportant, as long as they are swapping above and below 0.5v frequently, like once per second or so.
