protoj · 12 hours ago 12 hr
Got the car fixed at zed-world and they did a fantastic job cambelt change and second hand air flow metre as mine was totaly caput also thermostat, inlet hoses and anti-freeze . Carnt praze them enough they got me back on the road in no time fantastic :hyper:
