Ideas on Gauges
Right guys, I need your considered advice and expertise; I want to put in three extra gauges in the extra DIN slot so:
1. Where can i get gauges that look STOCK (i.e. same colours and intensity of lighting - completely stock to match speedo).
2. Which gauges are recommended?
3. Most people say go for water temp gauge - isnt the Oil temp the important thing?
4. I was thinking of getting two analogue gauges and one digital readout - does anyone know of any readout that looks like the display in the aircon system on a series II (i.e the Blue digital readout)?
Cheers guys
The TIM ones look close to stock if i remember correctly, Id go for water and oil temp, oil pressure and boost as a minimum
Cheers guys
If you have the dosh go for the Defi Link BFs ive just bought a set and they are the dogs dangalies.
All singing and dancing when you switch on and off.
Cheers guys,
where would i get a look at the TIMS gauges?
Any pics of your new Defi LInk BFs dude?
Also did you wire them in yourself?
Have you got a 60mm DIN slot? The only gauge holders i can find are 52mm!
No these are 52mm and i dash mounted them as they come with their own pods.
fook me its the starship enterprise!!!!
dials and gadgets galore!!!!!!!! :bow:
LOL yeh the missus calls me a big kid but i would be lost without them.
Ive run out of room for any more.
They look nice mate - where did you source them from?
I bought them localy RSE motorsport as i needed them desperatly as i had no oil pressure gauge after fitting my new turbos.
Thought all Defi gauges are 60mm? Pretty sure they are.
i thought 52mm
mmm ill check tomorrow
Cheers guys
The stock water temp and oil pressure gauges are famously unreliable, hence why so many fit aftermarket.
Most usefull (in order):
boost
Water temp
oil pressure
oil temp
If your going to fit them in your DIN panel, then I would recomend getting gauges that offer Peak warning features, as you wont be able to keep an eye on them from down there, but at least they will light up and/or make an audible sound if something is wrong.
theres two types of defi gauges available the BF range which steve has they only come in 60mm & the defi link system range which come in 52mm,60mm,80mm & 115mm option of black/white face, plus you have to buy a control unit to run any defi gauge, blitz do some very nice gauges as well but are a bit pricey.
i used a pod
I like the look of them sat up there.
I put a post up a week or two back asking for ideas on where to put them as I wasn't sure how they would look, but they look good.
Mind if I coppy your idea in the future?
Be my guest
Allthough im now thinking of putting my boost gauge on a single A pillar pod
and putting a oil temp where he boost is,so i have the 3 across the dash and 1 on the A pillar.
  • 1 month later...
i used a pod
I've been debating that type of install - but how do you block off the heater vents?
J
