Ecu Question
Hello,. i have a auto 92tt german.. whit ash spec ecu..but it does no convince..only boost at 0,6bar.
how as better emprom for this european 300zx??
thanks!
  • Replies 29
  • Views 886
hello!! i have bought the E.C.U temperature sensor (error13) an check again the ecu and no problem (code 55)!! i notice a little but boost whit fue 98 octane
the gauge maintain 0.7 bar :(
Does the car ever go above 0.4bar?
Once the engine is warm it should boost to whatever the boost jets are set at.
If fuel is causing detonation then it would go into safety boost but you should still see more boost initially.
If it's never going over 0.4 then maybe a faulty boost solenoid/boost leak/faulty turbo?
0.7 is about correct for a stock Z so are you sure you have boost jets installed and what size are they?
my boost jets is 1mm.. where to be a boost solenoid and boost leak?? thanks!
ohh my zed is germany this turbos is garret tb-22 and different camshafts
