LED rear lights
Has anyone got these from luke (z centre ) having spoken to him the layout is that the outer ring of small bulbs are used as brake lights with the inner single bulb the tail light. Has anyone changed this around and used the outer ring of lights as the tail lights and using a higher wattage bulb made the inner single light the brake light ? May all sound confusing but to anyone who has done this you will understand ! Thanks.
I use the outer rings as tail lights, but because they are so bright I had to have the rings painted which I feel looks better anyway. Then the two inner lights on the outer edges of the car I use as indicators. The middle inners I have High Intensety 29 bulb LED brake light bulbs + tail skin and spoiler for brakes the inners are reverse lights abd the two little reflectors by my eXhausts are also Fog lights
looks O.K. on your car colour but wanted to keep all the lenses clear for my gunmetal colour as all the other lights on car have clear lenses. cheers.
Trust me it'll look the dogs dangly's on gun metal aswell. Better than clear. I they are clear on the back it looks like its got two front ends.
At the moment i use the outers (led's) as brakes, they are real bright! to much for lights.
I do like markzx idea mind.
The two inner (single bulbs) closest to sides as the lights, and indicators the last inner (closest to each other), hope that makes sense.
Chris
also where did you get the reflector/ foglights ?
Markzx can i ask what/how paint you used?
When car was having a full colour change. I had Lukes very first set of these even before He had any for his car. The body shop mixed a red laqer, but you can get one mixed for aerosol at Halford. Most important thing to remember is to get a proper plastic primer. The clear type.
I got an extra pair of inner lights. Put aluminium flashing tap round the sides to make it directional and brighter. Then I bought 2 round trailer reflectors from the caravan shop and stuck then on the lenses. they act as reflectors for MOT and prefect fogs.
I would have just used the most inner centre lense N/S for fog and its oppersite number for reverse, but I live in the sticks and we've loads of building work going on so I need good reverse lights.
