clutch problem
hi guys,i done a search but didnt really find much,i just got an rps flywheel and rps organic max series clutch fitted to my car,it slipped once on the day i picked it up and now just slipped again 4 days later,ive tried putting it in 5th at 50mph and flooring it and it doesnt slip,any ideas?
my spec is below if it helps
thanks in advance
Paul
thanks in advance
Paul
Probably not slipping in 5th cause it doesnt have enough power at 50 to make it slip, just a thought, is the old clutch back in?? lol
not that i know of,lol
even in any gear at any speed i cant get it to slip,even on full boost and one of the times it did slip it was under normal driving off boost.
thanks again
Paul
Have you checked the pedal set up as when fitting uprated clutches you need to set the clutch pedal to allow more travel,there is a write up on twin turbo .net, basically setting clutch by backing off the swithces which are attached to the pedal box, so to allow for expansion , richard
