protoj · Tuesday at 18:48 1 day
Hi there people,Im all been well going to get a 300 for this summer and just wondering if you guys can tell me what to look out for and what not.How many 300`s (models) are there?Whats this 2+2 etc...
Anyhelp much appreciated. :dance:
