wiring water temp guage
anybody got a link of where I can take a feed off for the temp guage have done a search but didnt find out
cheers
Tommo mate. I will have a look at mine tomorrow. I fookin can't remember LOL. I fed all my guages off one main feed if i remember right.
[sIGPIC][/sIGPIC]
You need one of these
why not buy a gauge which comes with a sender and then drill and tap it in the metal pipe next to the original unit.
got one bud off you lol
should off made my self clearer 3 points on back of gauge
1. to the sender
2. to earth
3. **** knows :confused: ign? where can I splice this into? colour off the wire etc
cheers
Mate, will look now!!
[sIGPIC][/sIGPIC]
Right then, been out and took a quick photo. Its the black and red wire matey. I took it off there and used that for the main feed for all my guages. I earthed it by looking up inside the foot well by the bonnet release and found a bolt. A bit awkward but worth it.
[sIGPIC][/sIGPIC]
Just behind the ignition barrel. Below the steering column bud.
[sIGPIC][/sIGPIC]
sender and guage thought just the guage needed earthing?
how do you earth the sender?
if u are using the metal adapter pipe there will be a little crosshead screw on it for earthing the sender.
If the sender is fitted to a metal water pipe it will earth itself through contact with engine
adaptor like in pic bud so that has to be earthed aswell
that screw you can just run a small length of wire to an earth around the engine bay if need be
ive got a greddy 1 dont know if it has that? will check tomorrow
hasnt got anywhere to earth on the Greddy hose adaptor
hmmm
for mine to work it had to have the sender earthed , and I used a pipe adaptor and mine had a earth screw on it.
I think its a suck it and see moment.
no reading have earthed gauge ran wire to ignition and to sender
you will need to earth the sender then
try a bit of wire touching the thread of the sender that is earthed and see if you get a reading
