Front wheel camber
I was changing the discs and pads on the front the other day and found that the front pass tyre had eaten itself on the inside. I mean EATEN. The rest of the tyre was fine. This is obviously wrong and I need to get it fixed asap. Anyone know how and what it should be? I gave 17 inch Work alloys.
adjustable front upper arms bud have a look in the traders section not to cheap though
Very common problem on these cars mate, you will need these products:http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=4621712094&ssPageName=STRK:MEWA:IT The lower ones are here:http://www.conceptzperformance.com/Cart/description.php?II=760&Car_Type=300&UID=2006031711072782.32.199.226 the upper ones are here:http://www.conceptzperformance.com/Cart/description.php?II=624&Car_Type=300&UID=2006031711072782.32.199.226 You might need to upgrade your suspension as well mate.
if you look at my car, it looks as tho the front wheels are closer together at the top than at the bottom. is this because it has been lowered? they are like this / \
yup. too much negative camber.
how do i sort this then? it must be loads of negative camber as a few people have mentioned it
BazzaJG is selling a "Camber Correction shim kit (never used) 35 pounds" in the Items for sale section
Gary
