Almost had enough of this
Im so bloody pissed off with this zed ive put loads of cash into it and the sodding thing decided to blow the rad up today why wont these things just f*cking drive without needing constant attention pass me the hammer one smashed up zed coming right up
It's posts like this mate that makes me glad I did what I did!-don't worry! it's only a Rad, get a Koyo and forget it mate! :)
cheers manta but forgot to add its also running like a bag of shit it was fine when it was parked up now it is constantly missing one would a chip change do this to the arsehole thing? pass me the hot crack pipe there must be someway I can hurt my zed with it
Make sure the connection to the ecu is nice and tight ... if it isn't it can cause problems ...
not too tight though .. don't want to break anything, particularly the harness ..
If it started playing up after the chip change dude-I would certainly start there!-make sure the connector is on square and no pins are bent!-easy done! :)
I can understand how you feel.
I've had my car for a month or so, drove it about 5-6 times and the engines coming out now cause its fooked!!!!!!
The joys of exocitc cars...
Only problem i've had is my speedo, its been 3 weeks now and i've tried just about everything! Still doesn't work, so naturally, my Hicas doesn't work, my cruise control doesn't work, my gear changes are high, all cos a stupid needle doesn't want to move! But as annoying as it is, you have to laugh, what other car can cause so much enjoyment by tormenting you!
ill second that :smash:
hope all works out for you mate
Got a pulse from the gearbox, and a pulse up behind the clocks, the convertor box has been replaced and still nothing! Thinking of fitting uk spec clocks and doing away with the convertor completely!
oh sod it I felt like smashing it up with the hard end of a ratchet I guess its koyo rad for me and a jerky drive to ztech or zen garage:(
hay jd see anything familer lol
looking good mate :)
try ebay in america do a search for howe rads for the 300zx I had one on mine when my rad burst :rolleyes: or try Z1motorsports you will have it with in a week
thanks jd ill check those howe rads out I think chris from get greedy has a koyo rad lined up for me to be honest any rad will do this bloody thing hasnt moved in three months oh and fingers there just ebay el glow clocks nothing special
i no a place that can reconditon the rad put a new core in and reseal any joints that are cracked etc there based in crystal palace ,arron radiators they did my pas toyota hiace rad for 115, and it looked like brand new , as they also resprayed it as well , where as toyota wanted 425 for new rad !!!
cheers paul although I dont think you can recon this one it blow the top hose connection to peices and if I have to buy a new one I might as well buy one of those fancy koyo or howe things;)
LMFAO :D
Welcome to proper Zed ownership, in answer to your question...because it isn't a Toyota! LOL ;) Yep the car in front...always!!!
With Koyo's I do'nt think the original radiator fan shrouds will not fit IIRC
no need I have a kenlowe;)
LMFAO :D
Im glad you find it amusing......I dont
