In memory of Mandy
nzr pc help pleeeeese !!
hi guys,
ok where do i start then :bow:
im building a pc at the mo
mother board http://www.msi.com.tw/program/support/download/dld/spt_dld_detail.php?UID=608&kind=1
antec psu
maxtor sata hard drive
1 gig memory
i bought most of the stuff second hand off ebay :x:
so im just hopeing everything works ok :smash:
bought an ati readon graphics card 2day as the mobo didnt have one
i havent installed a cd rom or a floppy at the mo as i just wanted to see something on screen before i went futher!!
so all i have is the agp graphics card and the sata in plug sata 1
i also have a freeview pci card in there and there is a red light on that,
my question is there is nothing at all on my moniter!!
it just stays on standby and it does'nt come on when i switch my comp on just stays on stand by, i know the moniter works fine!!
2day was the first time i switched it on i hope ive done everything ok, and yep ive plugged the psu into the mobo both the plugs!!
where have i gone wrong guys :headvswal
any help much appreceated :duffer:
dewi
the PC should boot up with just the motherboard, Chip and memory
are you getting a system test? (bleeping sound)
make sure you are pluging the monitor into the graphics card not the motherboard as most have a onboard one
from what u have brought sounds like a good setup, ANTEC are Excellent PSU's, i have one :)
go back to basics m8, unplug EVERYTHING and start over, this time just plug in the motherboard, Chip and memory and graphics card
if it still dont boot up then there is sumthing wrong with the hardware, prob the motherboard is shot :( pity your not near me otherwise i would sort it for you.
sounds to me like u have done everything right, just re check everything and try again
Hope this helps
thanks mark :bow:
yep back to baisics had a look at the memory i was trying to use in dual channel :x:
took one out and worked straight away :tongue:
my next question is,
well i bought a 64bit 4000+ processor from this fella on ebay,
and on the boot up screen it says amd 3200+
can this be right??
it should have a clock speed of 2.4 ghz
is there a way i can check what chip is in there :smash:
or has this fella done me over :smash: :smash:
thanks
dewi.
right m8, 3 options here:
1) you have been dun over
2) your motherboard may not detect the full speed and may need a bois update
3) check the serial code with AMD
:duffer:
ok will do that matey cheers
i have looked on the clock speed on the bios and it says 2000 where it should say 2400 but i hope it is the motherboard that may need updating as you say
thanks mark.
just looked at the serial code on the chip and yep its a fVcking 3.2,
so he's trying to do me over is he!!
well i have just sent him an email telling him to get it sorted asap and for him to send me the proper chip then i will return the other one
could be just a genuine mistake!!
but could also be trying it on also, lets wait and see shal we!!
glad u checked it out m8
could be a honest mistake but even so still not on
hope u get the right one :)
just got an email from the fella saying he will swap the 3200 for a 3800 dual core whats the best the amd 4000 or the amd 3800 dual core??
will the dual core also fit the fan im using at the moment to cool the 3200 amd socket 939?
deff get the 3800 dual core, they are sweet
u will need a diff fan though
dual core is better its a 3800 x2 ;) surprised he is going to give you that there exspensive but you need to make sure that your mobo supports x2 check msi website
yeah though so, thanks fellas, i have checked the msi website andthe mobo supports the dual core !
i'll let you know how i get on
thanks again
dewi
hi guys,
why bother just go to pc world & get a new one for £500
do you know whats in those Pc's m8?
shit parts, nothing that is any good
crap Ram, crap graphic cards (prob on-board)
sumtimes it is cheaper and better to build your own. i build mine cose i had to have a got spec PC cose i play games competivly on a regular basis.
To them a 2 year old graphic card is the "best" on the market, half the staff ant got the first clue about PC's. Ask them about the new 7900 series cards and you would get a blank look.
PC's they sell are ok for net use and stuff but not cut it if you wanna play games
hi guys,
for the same reason you wouldn't take your car to nissan
try and get the specs you want for half the cash you could build one for,
if you can find your way past the celeron's and the untrained monkeys who
mostly know as much about computers as i do about space travel, :headvswal
Good points there if checking the net is your bag then great but I built my own because I wanted it quite,fast and able to play the latest games
